Creating Aggregate Volume Discounts for Sleeping Rooms and Suites
A sleeping room aggregate volume discount is a volume discount that applies to all types of sleeping rooms at a specific property. Siebel Hospitality allows you to create aggregate volume discounts for sleeping rooms.
For example, a property has three different types of sleeping rooms (single room, double room, and penthouse suite). A customer books 10 rooms of each type, which means the customer books a total of 30 rooms. Instead of giving a separate discount for each room type, you can give the customer one aggregate discount for all 30 rooms.
Before you perform this procedure, you must create a volume discount, as described in Creating Volume Discounts. Additionally, you must add line items to the volume discount, as described in Adding Volume Discount Line Items.
To create an aggregate volume discount for sleeping rooms and suites
  1. Navigate to the Property Pricing Admin screen, then the Properties view.
  2. In the Properties list, select the required property and click the link in the Property Name field.
  3. Click the Volume Discount Matrix view tab.
  4. In the Volume Discount Matrix list, create a new record.
  5. In the Product Line field, click the single select button, and in the Pick Product Line selection dialog box, select the Sleeping Room product line.
  6. Complete the remaining fields, while making sure that you leave the Product field blank, and save the record.
    For more information on these fields, see Associating Volume Discounts with a Property.
