Entering Records for Competitor Properties (Administrator)
Siebel Hospitality can capture historical and future information from competitor properties as well as for your property and its sister properties. To allow users to add historical and future records for competitor properties, you must create records for these competitor properties.
This task is a step in Process of Setting Up Histories and Futures Data.
To enter records for competitor properties
Follow the steps of Adding Property Records.
In the Property Type field, select Competitor.
Complete the other fields, as required.
Note: Properties that you designate as competitor properties
can only be viewed and selected by users in the Histories screen,
Quotes list.
