Overriding the Average Values for Subfunction Categories
During the initial setup of the average values of a property, the revenue manager assigns average values to the various function types that exist at a property. The revenue manager uses past history to estimate the average revenue contributions associated with each function type.
During the opportunity capture stage, the sales representative might not fill in all information about a function, and might decide to keep the function details at a very high level. As a result, only the details of the main functions might have been added to the event agenda, and not subfunction details.
This means that when the sales representative decides to detail the function by adding subfunctions, the revenue contributions are added twice to the function. This is because some of the categories for the function can be added at both the function level initially and then at the subfunction level when the function is detailed. For example, a Meeting function can be added to an opportunity with an Audio Visual and Coffee Break revenue contribution.
Later, the sales representative might decides to add the Coffee Break as a subfunction of the main function. In this case, the revenue contribution for the function has been added twice. In order to make sure that the revenue contribution is not mistakenly counted twice, an average value override for subfunctions has been put in place in Siebel Hospitality. This average value override is subject to a number of rules as follows:
Rule 1: The subfunction category revenue estimate takes precedence over the estimate that exists at the parent function level.
Rule 2: Multiple subfunction revenues of the same category are added together.
Rule 3: The subfunction category revenue override facility overrides one function level higher than the level at which it exists.
The rules for function category average value overrides are illustrated in the following examples:
Example 1: One main function that contains two subfunctions
Example 2: One Main Function that Contains a Subfunction and a Child Subfunction of the Subfunction
Example of a Function with Two Subfunctions
The following table provides the details of the main function.
Function Name | Function Type | Parent Category | Category | Revenue |
Function 1 |
Meeting |
Food |
(Not applicable) |
130 (Total revenue) |
Lunch |
100 |
Coffee Break |
30 |
The following table provides the details of the first subfunction.
Subfunction 1 |
Coffee |
Food |
(Not applicable) |
45 (Total revenue) |
Coffee Break |
45 |
If the user indents Subfunction 1 under Function 1, then Rule: 1 applies; The subfunction category revenue estimate takes precedence over the estimate that exists at the parent function level. The following table shows the changes to Function 1 when Subfunction 1 is indented.
Function 1 |
Meeting |
Food |
(Not applicable) |
100 (Total revenue) |
Lunch |
100 |
Coffee Break |
0 |
The Coffee Break revenue is overridden and is set to 0 at the parent function level. This means that the revenue estimate that is displayed at the quote level would be as shown in the following table.
Food |
(Not applicable) |
145 (Total revenue) |
Lunch |
100 |
Coffee Break |
45 |
At this stage, the sales representative decides to add another subfunction to the parent function, Function 1. The following table shows the details of this subfunction.
Subfunction 2 |
Meeting |
Food |
(Not applicable) |
25 (Total revenue) |
Coffee Break |
25 |
When this subfunction is added, Rule: 2 is applied; Multiple subfunction revenues of the same category are added together. This is shown in the following table.
Subfunction 1 + 2 |
Meeting |
Food |
Coffee Break |
70 |
Subfunction 1 |
Meeting |
Food |
Coffee Break |
45 |
Subfunction 2 |
Meeting |
Food |
Coffee Break |
25 |
The revenue estimate that is now displayed at the quote level is shown in the following table.
Food |
(Not applicable) |
170 (Total revenue) |
Lunch |
100 |
Coffee Break |
70 |
Example of a Function with a Subfunction and a Child Subfunction
Function 1 |
Meeting |
Food |
(Not applicable) |
Lunch |
100 |
Coffee Break |
30 |
The following table provides the details of the subfunction.
Subfunction 1 |
Coffee |
Food |
(Not applicable) |
Coffee Break |
45 |
If the user indents Subfunction 1 under Function 1, then Rule: 1 applies; The subfunction category revenue estimate takes precedence over the estimate that exists at the parent function level. The revenue estimate that is displayed at the quote level would be as shown in the following table.
Food |
(Not applicable) |
Lunch |
100 |
Coffee Break |
45 |
The sales representative then decides to add a child subfunction to the existing function. The details of this child subfunction are shown in the following table.
Child Subfunction 1 |
Coffee |
Food |
(Not applicable) |
Coffee Break |
25 |
The following table shows the changes to the Subfunction 1 when Child Subfunction 1 is indented.
Function 1 |
Meeting |
Food |
(Not applicable) |
0 (Total revenue) |
Coffee Break |
0 |
Rule 3 is the applied: The subfunction category revenue override facility overrides one function level higher than the level at which it exists. The revenue estimate that is displayed at the quote level would then be as shown in the following table.
Food |
(Not applicable) |
125 (Total revenue) |
Lunch |
100 |
Coffee Break |
25 |
