Setting Up Day Parts
To set up day parts, follow this procedure.
Note: Day parts can span two different days. For example, a day part might run from 10 P.M. until 3 A.M. However, day parts can span only one 24-hour time period.
To set up day parts
  1. Navigate to the Property Administration screen, then the Properties view.
  2. In the Properties list, query for and select the required property.
  3. Click the link in the Property Name field, and then click the Day Parts view tab.
  4. In the Day Parts list, create new records, complete the fields for each record, and save the records.
    The following table describes some of the fields.
    Field Comments
    Day Part Name
    The name of the day part, for example, Morning.
    Start Time
    The start time of the day part, for example, 6 A.M.
    End Time
    The time that the day part ends, for example, 12 P.M.
    Include in Full Day Threshold
    This check box is used to indicate whether the day part will be a part of the Full Day Threshold for discounts.
    • If selected, no function can qualify for a full day discount unless the function touches this day part.
    • If cleared, functions can qualify for a full day discount without touching this day part.
    Comments
    Add any relevant comments about the day part.
