Setting Up Report Headers for Property-Specific Products
After administrators set up property-specific report headers, they can associate those report headers with the products assigned to the properties that use those report headers.
To set up a report header for a property-specific product
Navigate to the Property Administration screen, then the Properties view.
In the Properties list, query for and select the property associated with the product for which to set up a report header.
Click the link in the Property Name field.
Depending on the product for which you want to set up a report header, click one of the following view tabs:
Event Order/Menu Items
Menus
Packages
In the list of products, query for and select the product to associate with a report header.
In the Report Header field, click the select button, and select the report header.
If more than one value is available, you can select multiple values. The value in the Property field for the product determines the values that you can select in the Report Header field.
