Approving Point Blocks
After the loyalty manager creates the point block, another manager might have to approve it.
To approve point blocks
Navigate to the Loyalty Program Administration screen.
In the Programs list, select the program whose point blocks you want to approve and click its Program Id hyperlink.
Click the Point Blocks view tab.
In the Point Blocks list, use a query to find all point blocks with the value Submitted in the Status field.
To approve a point block, select Approved in the Status field.
