Defining Transient Variables for Existing Point Types
Transient variables can be added or removed like other program level attributes. When you create a new point type in a program, a new transient variable is automatically created and aligned with that point type. The Point Type field on the Transient Variable list has the same value as the point type that you defined.
If the point type already exists, then you can create a new transient variable and associate it with that point type. It is a one-to-one relationship: a transient variable can only be associated with one point type.
To define a transient variable for an existing point type
Navigate to the Loyalty Program Administration screen.
Drill-down on a program.
Click the Program Level Attributes tab.
Click the Transient Attributes tab.
Click New.
Complete the necessary fields. Some fields are described in the following table.
Field Description Name
Name of the transient variable
Point Type
Point type of the transient variable
Note: You must associate the transient variable with a Point Type.
