Defining the Distance Between Two Airports
You can define the distance between any two airports (or city pairs) for air travel in the Loyalty Distance table. The distances listed in the table can be used by a base promotion to calculate the base points for air travel.
To define the distance between two airports
Navigate to the Loyalty Program Administration tab and click Distance.
Click New and complete the following fields:
Field Comment Origination Airport
The originating airport for air travel.
Destination Airport
The destination airport for air travel.
Distance
The distance between the two airports (usually in either miles or kilometers).
