Return Values of Eligibility Promotions
Since eligibility promotions do not have user defined actions associated with them, they return only two possible values:
  • Success. When one or more rules are satisfied.
  • Failure. When no rules are satisfied.
Based on these status codes, Siebel Loyalty can decide whether to further process the promotion design for the related transaction.
Note: An eligibility promotion is evaluated only if it is a part of a promotion design. It is not evaluated during normal processing of transactions, even if it has been marked as Active.
