Application Events for Siebel eScript
The following table describes a summary of application events you can use with Siebel eScript.
Event | Description | Format |
Called before the Siebel application exits. |
Called after a specialized method is called. |
Called after the user navigates to a view. |
Called before Siebel CRM calls a specialized method. |
Called before the Siebel application displays the view where the user navigates. |
Called when the Siebel client starts. |
