Application Methods for COM Data Control
The following table describes a summary of application methods you can use with COM Data Control. It does not include object interface methods that Siebel CRM does not call directly from an application instance. For information about methods that Siebel CRM calls with the InvokeMethod method on the application object, see LoadObjects Method for an Application.
Method Description Format
Attach Method for an Application
Allows an external application to reconnect to an existing Siebel session.
Dim application as SiebelDataControl
Dim status as Boolean
status = application.Attach(sessionID As String)
CurrencyCode Method for an Application
Returns the currency code that is associated with the division of the user position.
Dim sCur as String
sCur = Application.CurrencyCode
Detach Method for an Application
Returns a string that contains the Siebel session ID.
Dim sessionId as String
sessionId = application.Detach()
EnableExceptions Method for an Application
Enables or disables native Component Object Model (COM) error handling.
Dim bEnable as Boolean
bEnable = trueapplication.EnableExceptions(bEnable)
GetBusObject Method for an Application
Creates a new instance of a business object.
Dim busObject as SiebelBusObject
set busObject = application.GetBusObject(busobjName as String)
GetLastErrCode Method for an Application
Returns the error code for the error that Siebel CRM logged most recently.
Dim iErr as Integer
iErr = application.GetLastErrCode
GetLastErrText Method for an Application
Returns the text message for the error that Siebel CRM logged most recently.
Dim sText as String
sText = application.GetLastErrText
GetProfileAttr Method for an Application
Returns the name of an attribute in a user profile.
Dim sText as String
sText = application.GetProfileAttr(profileAttributeName as string)
GetService Method for an Application
Locates a business service. If this business service is not already running, then Siebel CRM starts it.
Dim service as SiebelService
set service = application.GetService(serviceName as String)
GetSharedGlobal Method for an Application
Returns the shared global variables.
Dim sText as string
sText = application.GetSharedGlobal(globalVariableName as string)
InvokeMethod Method for an Application
Calls a method.
Dim sReturn as String
sReturn = application.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
Login Method for an Application
Allows an external application to log in to the COM Data Server, COM Data Control, or Siebel Java Data Bean, and to access Siebel objects.
Dim sErr as String
sErr = application.Login(connectString as String, userName as String, password as String)
LoginId Method for an Application
Returns the login ID of the user who started the Siebel application.
Dim sID as String
sID = application.LoginId
LoginName Method for an Application
Returns the login name of the user who started the Siebel application.
Dim sUser as String
sUser = application.LoginName
Logoff Method for an Application
Disconnects the Siebel client from the Siebel Server.
Dim SiebApp as SiebelDataControl
Dim boolVal as Boolean
boolVal = siebApp.LogOff
NewPropertySet Method for an Application
Creates a new property set.
Dim PropSet as SiebelPropertySet
PropSet = oApplication.NewPropertySet
PositionId Method for an Application
Returns the position ID of the user position.
Dim sRow as String
sRow = application.PositionId
PositionName Method for an Application
Returns the name of the current user position.
Dim sPosition as String
sPosition = application.PositionName
SetPositionId Method for an Application
Sets the active position to a Position ID.
status = application.SetPositionId(sPosId)
SetPositionName Method for an Application
Sets the active position to a position name.
status = application.SetPositionName(sPosName)
SetProfileAttr Method for an Application
Personalization uses this method to set a value for an attribute in a user profile.
application.SetProfileAttr(name as String, value as String)
SetSharedGlobal Method for an Application
Sets a shared global variable.
boolVal = SiebApp.SetSharedGlobal(varName As String, value As String)
Trace Method for an Application
Appends a message to the trace file.
boolVal = siebApp.TraceOn(msg As String)
TraceOff Method for an Application
Turns off tracing.
boolVal=siebApp.TraceOff
TraceOn Method for an Application
Turns on tracing.
boolVal = siebApp.TraceOn(fileName As String, category As String, src As String)
