ActivateField Method for a Business Component |
Activates a field. |
Dim oBusComp as BusComp
oBusComp.ActivateField fieldName as
String
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
oBusComp.ActivateMultipleFields
oPropSet as PropertySet
Associate Method for a Business Component |
Creates a new many-to-many relationship for
the parent object through an association business component. |
oBusComp.Associate whereIndicator as
Integer
BusObject Method for a Business Component |
Returns the name of the business object that
the business component references. |
Dim oBusObject as BusObject
Set
oBusObject = oBusComp.BusObject
ClearToQuery Method for a Business Component |
Clears the current query but does not clear
sort specifications on the business component. |
oBusComp.ClearToQuery
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently
active from the SQL query statement of a business component. |
oBusComp.DeactivateFields
DeleteRecord Method for a Business Component |
Removes the current record from a business
component. |
oBusComp.DeleteRecord
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
oBusComp.ExecuteQuery cursorMode as
Integer
ExecuteQuery2 Method for a Business Component |
Allows you to control the number of records Siebel CRM returns. |
oBusComp.ExecuteQuery2 cursorMode as
Integer, ignoreMaxCursorSize as Integer
FirstRecord Method for a Business Component |
Moves the record pointer to the first record
in a business component, making that record the current record. |
Dim iIsRecord as Integer
iIsRecord
= oBusComp.FirstRecord
FirstSelected Method for a Business Component |
Makes the first record of the multiple selection
in a business component active. |
Dim iIsMultipleSection as Integer
iIsMultipleSelection = oBusComp.FirstSelected
GetAssocBusComp Method for a Business Component |
Returns the name of the association business
component. |
Dim AssocBusComp as BusComp
Set
AssocBusComp = oBusComp.GetAssocBusComp
GetFieldValue Method for a Business Component |
Returns the value of a field from the current
record of a business component. |
Dim sValue as String
sValue = oBusComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method for a Business Component |
A field value that is in the same format
that the Siebel client uses. |
sValue = oBusComp.GetFormattedFieldValue(FieldName as String)
GetMultipleFieldValues Method for a Business Component |
Returns values for the fields specified in
a property set. |
oBusComp.GetMultipleFieldValues oFields as PropertySet, oValues as PropertySet
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component
associated a business component field. |
Dim MvgBusComp as BusComp
set MvgBusComp
= oBusComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
sValue = oBusComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component
that is associated with a field in the current business component. |
Dim pickBusComp as BusComp
Set
pickBusComp = oBusComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method for a Business Component |
Returns the current search expression that
is defined for a business component. |
Dim sExpr as String
sExpr = oBusComp.GetSearchExpr
GetSearchSpec Method for a Business Component |
Returns the search specification for a field. |
Dim sSpec as String
sSpec = oBusComp.GetSearchSpec(FieldName as String)
GetSortSpec Method for a Business Component |
Returns the sort specification for a business
component. |
Dim sSortSpec as String
sSortSpec = GetSortSpec
GetUserProperty Method for a Business Component |
Returns the value of a user property. |
sValue = oBusComp.GetUserProperty(propertyName as String)
GetViewMode Method for a Business Component |
Returns the current visibility mode for a
Dim iMode as Integer
iMode = oBusComp.GetViewMode
InvokeMethod Method for a Business Component |
Calls a method. |
oBusComp.InvokeMethod(methodName as
String, methArg1, methArg2, methArgN as String
or StringArray)
LastRecord Method for a Business Component |
Moves the record pointer to the last record
in a business component. |
Dim iReturn as Integer
iReturn
= oBusComp.LastRecord
Name Method for a Business Component |
Returns the name of a business component. |
Dim sName as String
sName = oBusComp.Name
NewRecord Method for a Business Component |
Adds a new record to a business component. |
oBusComp.NewRecord whereIndicator as
Integer
NextRecord Method for a Business Component |
Moves the record pointer to the next record
iReturn
= oBusComp.NextRecord
NextSelected Method for a Business Component |
Makes the next record of the current multiple
selection the active record. |
iReturn
= oBusComp.NextSelected
ParentBusComp Method for a Business Component |
Returns the name of the parent business component. |
Dim parentBusComp as BusComp
Set
parentBusComp = oBusComp.ParentBusComp
Pick Method for a Business Component |
Places the currently chosen record in a pick
business component into the appropriate fields of the parent business
component. |
oBusComp.Pick
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous
record in a business component. |
iReturn
= oBusComp.PreviousRecord
RefineQuery Method for a Business Component |
Refines a query. |
oBusComp.RefineQuery
SetFieldValue Method for a Business Component |
Sets a new value for a field in the current
oBusComp.SetFieldValue FieldName as
String, FieldValue as String
SetFormattedFieldValue Method for a Business Component |
Sets the new value to a field for the current
oBusComp.SetFormattedFieldValue FieldName as String, FieldValue as String
SetMultipleFieldValues Method for a Business Component |
Sets new values in the fields of the current
oBusComp.SetMultipleFieldValues oPropSet as PropertySet
SetNamedSearch Method for a Business Component |
Sets the named search specification on a
oBusComp.SetNamedSearch searchName as
String, searchSpec as String
SetSearchExpr Method for a Business Component |
Sets a search expression for a business component
rather than for each field. |
oBusComp.SetSearchExpr searchSpec as
String
SetSearchSpec Method for a Business Component |
Sets the search specification for a field. |
Dim oBusComp as BusCom poBusComp.SetSearchSpec fieldName as String, searchSpec as String
SetSortSpec Method for a Business Component |
Sets the sort specification for a business
component. |
oBusComp.SetSortSpec sortSpec as String
SetUserProperty Method for a Business Component |
Sets the value of a user property in a business
component. |
oBusComp.SetUserProperty propertyName as String, newValue as String
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
oBusComp.SetViewMode viewMode as Integer
UndoRecord Method for a Business Component |
Reverses any unsaved modifications that Siebel CRM has made on a record. |
oBusComp.UndoRecord
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications
made to the current record. |
oBusComp.WriteRecord
