Example of Using Siebel eScript to Create a Validation
The following Siebel eScript example creates a validation that queries a specific field to determine if the object interface event completed successfully or completed with a run-time error:
function BusComp_PreSetFieldValue (FieldName, FieldValue)
   var iReturn = ContinueOperation;
   //code to check if a quote discount > 20%
   //if it is, notify user and cancel the operation
   var varvalue;
   var msgtext;
   if (FieldName == "Discount")
      varvalue = ToNumber(FieldValue);
      if (varvalue > 20)
         msgtext = "Discounts greater than 20% must be approved";
         TheApplication().RaiseErrorText(msgtext); // cancels the run
      else
