Reset Method for a Property Set
The Reset method removes all properties and children from a property set. This method does not return any information.
Format
oPropSet.Reset()
No arguments are available.
Usage
The Reset method allows you to reuse a property set.
Used With
Browser Script, COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
