DeleteOrder Method
Deletes the order that matches the input.
Syntax
Product Data Service.InvokeMethod(“DeleteOrder", Input Arguments,Output Arguments);
Arguments
Argument Type Description
Input Arguments
In
Hierarchy :SiebelMessage(Integration object PDS Order)
Output Arguments
Out
Example of Input Arguments
PropertySet@0012D384 p#0 c#1 type="" vt=0 value=""
    c[0] PropertySet@0A6E4FE8 p#4 c#1 type="SiebelMessage" vt=0 value=""
        p["MessageId"] = "42-1D9U";
        p["MessageType"] = "Integration Object";
        p["IntObjectName"] = "PDS Order";
        p["IntObjectFormat"] = "Siebel Hierarchical";
        c[0] PropertySet@0ACADCC0 p#0 c#1 type="ListOfPDS Order" vt=0 value=""
            c[0] PropertySet@0A903FE8 p#17 c#1 type="Header" vt=0 value=""
                p["Account Location"] = "";
                p["Id"] = "42-50SHP";
                p["Revision"] = "1";
                p["Account Id"] = "";
                p["Status"] = "Pending";
                p["Conflict Id"] = "0";
                p["Order Type"] = "Service Order";
                p["Account"] = "";
                p["Contact Id"] = "";
                p["Currency Code"] = "USD";
                p["Discount"] = "";
                p["Updated"] = "02/11/2005 13:54:39";
                p["Integration Id"] = "";
                p["Opty Id"] = "";
                p["Order Number"] = "PDS Order Item Test";
                p["Created"] = "02/11/2005 13:54:39";
                p["Price List Id"] = "";
                c[0] PropertySet@0A900550 p#0 c#1 type="ListOfLine Item" vt=0 value=""
                    c[0] PropertySet@0AB61530 p#62 c#1 type="Line Item" vt=0 value=""
                        p["NRC CxTotal"] = "0";
                        p["Parent Id"] = "";
                        p["Cfg State Code"] = "New Item";
                        p["Volume Discount Item Id"] = "";
                        p["Id"] = "42-50SHW";
                        p["Cfg Type"] = "";
                        p["Eligibility Reason"] = "";
                        p["Exclude Pricing Flag"] = "N";
                        p["Extended Quantity Requested"] = "1";
                        p["Asset Integration Id"] = "42-50SHW";
                        p["Root Id"] = "42-50SHW";
                        p["Need Refresh"] = "Y";
                        p["Prod Prom Name"] = "";
                        p["Volume Discount Item"] = "";
                        p["Line Number"] = "1";
                        p["Product Id"] = "42-50S1M";
                        p["Smart Part Number"] = "";
                        p["Discount"] = "";
                        p["Prod Item Id"] = "";
                        p["Discount Percent"] = "";
                        p["Original List Price"] = "";
                        p["Updated"] = "02/11/2005 13:56:09";
                        p["Current Price"] = "";
                        p["Eligibility Status"] = "";
                        p["Port Item Id"] = "";
                        p["Prod Prom Id"] = "";
                        p["Has Generics Flag"] = "";
                        p["Inclusive Eligibility Flag"] = "N";
                        p["Integration Id"] = "42-50SHW";
                        p["Post Pick CD"] = "";
                        p["Prod Prom Instance Id"] = "";
                        p["Rollup Amount"] = "0";
                        p["Forcastable Flag"] = "";
                        p["Prod Prom Rule Id"] = "";
                        p["Discount Source"] = "Manual";
                        p["List Price"] = "";
                        p["Pricing Comments"] = "";
                        p["Volume Upsell Item"] = "";
                        p["Effective To"] = "";
                        p["Unit Price"] = "";
                        p["Price Type"] = "One-Time";
                        p["Product Line Id"] = "No Match Row Id";
                        p["Rollup Item Price"] = "0";
                        p["Volume Discount Id"] = "";
                        p["Created"] = "02/11/2005 13:54:50";
                        p["Due Date"] = "02/12/2005 00:00:00";
                        p["Effective From"] = "";
                        p["Prod Prom Source Id"] = "";
                        p["Discount Amount"] = "";
                        p["Exchange Date"] = "";
                        p["Item Price List Id"] = "";
                        p["Pre Pick CD"] = "";
                        p["Volume Upsell Message"] = "";
                        p["Configuration Model Id"] = "42-50S1M";
                        p["Name"] = "PDS Product";
                        p["Quantity"] = "1";
                        p["Action Code"] = "Add";
                        p["MRC CxTotal"] = "0";
                        p["Volume Upsell Item Id"] = "";
                        c[0] PropertySet@0A92EE38 p#0 c#0 type="ListOfXA" vt=0 value=""
PropertySet@0012DA78 p#0 c#1 type="" vt=0 value=""
    c[0] PropertySet@0AB9F028 p#4 c#1 type="SiebelMessage" vt=0 value=""
        c[0] PropertySet@0AC32B10 p#0 c#1 type="ListOfPDS Order" vt=0 value=""
            c[0] PropertySet@0A63EB20 p#0 c#0 type="Header" vt=0 value=""
None.
This method calls the help method described in DeleteQuote Method.
