Parameters for Configuring Siebel Product Configurator Caching
This topic is part of About Siebel Product Configurator Caching.
Siebel Product Configurator caching is enabled by default (eProdCfgSnapshotFlg is set to TRUE). Other parameters must be sized following guidelines such as those described in Determining Rough Sizing for Caching Parameters.
This topic lists the server parameters for configuring Siebel Product Configurator caching. Set these parameters on the Siebel Application Object Manager component for a Siebel Application Object Manager deployment of Siebel Product Configurator. For a dedicated Siebel Product Configurator server deployment, set these parameters on the Siebel Application Object Manager and on the eProdCfgObjMgr component, unless otherwise stated. For information on how to configure server parameters, see Siebel System Administration Guide.
Parameter Alias
Parameter Name
Data Type
Default Value
Description
eProdCfgCacheFS
Product Configurator - FS location
String
Not applicable
Specifies the location of the Siebel Product Configurator File System. If no value is specified for eProdCfgCacheFS, then Siebel Product Configurator looks in the Siebel File System. For more information, see Specifying the Siebel Product Configurator File System Location.
eProdCfgAttrSnapshotFlg
Product Configurator - Collect and Use the snapshots of the ISS_ATTR_DEF Ob
Boolean
TRUE
Set to TRUE to enable caching for attribute definitions. This caches attribute definitions in memory. It is strongly recommended that you do not change this parameter.
eProdCfgNumOfCachedAttrs
Product Configurator - Number of Attribute Definitions Cached in Memory
Integer
100
Sets the number of attribute definitions kept in memory at any given time during configuration.
eProdCfgClassSnapshotFlg
Product Configurator - Collect and Use the snapshots of ISS_CLASS_DEF Ob
Boolean
TRUE
Set to TRUE to enable caching for product class definitions. It is strongly recommended that you do not change this parameter.
eProdCfgNumOfCachedClasses
Product Configurator - Number of Class Definitions Cached in Memory
Integer
100
Sets the number of class definitions kept in memory at any given time during configuration.
eProdCfgProdSnapshotFlg
Product Configurator - Collect and Use the snapshots of ISS_PROD_DEF Ob
Boolean
TRUE
Set to TRUE to enable caching for product definitions. This caches product definitions in memory. It is strongly recommended that you do not change this parameter.
eProdCfgNumOfCachedProducts
Product Configurator - Number of Product Definitions Cached in Memory
Integer
1000
Sets the number of product definitions kept in memory at any given time during configuration.
eProdCfgSnapshotFlg
Product Configurator-Collect and use snapshots of the Cfg objects
Boolean
TRUE
Set to TRUE to turn on Siebel Product Configurator caching. It is strongly recommended that you do not change this parameter.
eProdCfgNumbOfCachedCatalogs
Product Configurator-Number of cached catalogs
Integer
10
Sets the maximum number of Model Manager catalogs that can be cached in memory. Catalog data is flushed from the cache on a least recently used basis.
eProdCfgNumbofCachedWorkers
Product Configurator-Number of workers cached in memory
Integer
50
Sets the maximum number of workers that can be cached in memory. This number applies to all Model Manager catalogs.
eProdCfgCacheEngineObjects
Product Configurator - Cache Engine Objects
Boolean
TRUE
Set to TRUE to enable content cache and precaching.
Note: This parameter supports precaching. Set this parameter only on the dedicated Siebel Product Configurator server. Precaching does not apply on the Siebel Application Object Manager.
See also Cache Management for Siebel Product Configurator.
ServerSessionLoopSleepTime
Server Session Loop Sleep Time
Integer
300
Specify an interval time (in seconds) to refresh cached products that are mapped to a Siebel Product Configurator server cache or component cache using the explicit product mapping setting.
Product Configurator - Cache Engine Objects must be set to TRUE.
