Converting a Bundle to a Regular Product with Components
A bundle is a group of items sold as one product and is a special form of product with components. A bundle has one or more relationships that have a Product domain. Bundles do not include a UI definition, configuration rules, links, resources, or scripts.
When you convert a bundle to a regular product with components, you can work with the newly converted product with components in the same way as a regular product with components.
To convert a bundle to a regular product with components
Navigate to the Administration - Product screen, then the Product Definitions view.
In the Products list, select and lock the desired bundle product.
Click Release.
This converts the bundle to a regular product with components. A check mark displays in the Customizable Product check box in the Product record. A check mark no longer displays in the Bundle check box.
Revise existing quotes and orders as needed to reflect the change.
