Copying Products with Components
When you copy a product with components, all parts of the product are included in the copy. This includes its relationships, links, resources, scripts, rules, and its user interface.
All the parts of the copied product are visible and can be edited.
To copy a product with components
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, select the desired product with components.
  3. From the Products menu, choose Copy Record.
  4. Enter a name for the copy in the Product Field.
  5. Revise other fields, such as Part # as desired.
