Editing a Relationship Definition
You can only edit the current work space of a product with components. You cannot edit a version that has already been released. All the fields in a relationship definition can be edited except the relationship name. Changes are not propagated to other parts of the product with components.
To edit a relationship definition
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Products list, select and lock the desired product with components.
  3. In the Versions list, click the Work Space version.
  4. In the Explorer applet, select the desired relationship.
  5. Edit the fields in the Structure record as desired.
  6. Revise configuration rules, resource definitions, link definitions, and scripts as needed to reflect the changes.
