Name-Based Import
If you have failed to create a master product database and you already have multiple databases with different object identifiers for the same objects, object identifier-based import fails. In this case, you can use name-based import. Name-based import is not recommended. Use it only as a last resort.
Name-based import is done using the ISS Authoring Import Export business service. For more information, see Siebel Order Management Guide.
