Process of Creating a Custom Siebel Configurator User Interface
To create a custom Siebel Product Configurator user interface, perform the following tasks:
Creating the Siebel Product Configurator User Interface Record
Enabling the Multiselect Feature for Siebel Product Configurator
Enabling the Quick Edit Feature for Siebel Product Configurator
Grouping Items onto Pages of the Siebel Product Configurator User Interface
Adding a Summary Page to the Siebel Product Configurator User Interface
Caution: In the Customizable Product UI layer, the type
of the user interface controls must match with the type of the user
interface option and the base theme type of the user interface option.
If the types do not match, the user interface will be rendered incorrectly
or there will be runtime errors. For example if you select a Customizable
Product menu base theme, then you must only select relationship or
attributes controls for menu theme.
