What’s New in Siebel Product Administration Guide, Siebel CRM 19.4 Update
The following information lists the changes in this revision of the documentation to support this release of the software.
New Product Features in Siebel Product Administration Guide, Siebel CRM 19.4 Update
Topic Description
About Predefined UI Properties
Updated this section to include the predefined UI property: EnableOraCfgEngine
About the Siebel Constraint Engine
Updated this section to include the different behaviors between the Siebel Constraint Engine and existing constraint technology.
Process of Setting Up Siebel Constraint Engine
Removed the section that described how to activate the Cfg Ora Engine Runtime Interaction Workflow. This workflow is no longer required.
Setting Up the Siebel Constraint Engine System Preference
Removed the system property: ConstraintEngineHost. This system property is no longer needed.
About Configuration Resources
Updated this section to include how the Siebel Constraint Engine defines resources as an integer type.
