Creating Accounts and Passwords
This task is a step in Process of Configuring Encryption and Authentication for the Remote Client.
You must create an account for each client to authenticate a remote client when it synchronizes. The authentication method you choose determines the account you must create.
To create accounts and passwords
Create an account and password according to the type of authentication you use. Use values from the following table.
| Authentication | Work You Must Do |
AppServer authentication |
Create a user account on the Siebel Server for each remote client:
For more information, see How the Change Password Functionality Affects Authentication. |
Database authentication |
Create a database account and password for each remote client. |
Siebel authentication |
Do the following:
SecurityAdapter authentication |
Create the accounts and passwords that your third party authentication system requires. For example, it might be necessary for you to create records in an LDAP folder. |
No authentication |
Do not create accounts or passwords for authentication. |
