Querying for Orphan Records
To examine orphan records in the Siebel database, you can use an SQL query. This query locates rows in the S_DOC_TXN_LOG table that meet any of the following conditions:
Row ID is not equal to the parent transaction ID
The parent transaction ID does not equal the row ID of any other row in the table
To query for orphan records
Query for the orphaned records:
To query in Oracle Database, use the following command:
SELECT B.TXN_ID, B.ROW_ID, B.PAR_TXN_ID, B.OPERATION, B.ITEM_NAME FROM S_DOCK_TXN_LOG A, S_DOCK_TXN_LOG B WHERE A.ROW_ID(+) = B.PAR_TXN_ID AND A.ROW_ID IS NULLTo query in IBM DB2 or Microsoft SQL Server, use the following command:
SELECT B.TXN_ID, B.ROW_ID, B.PAR_TXN_ID, B.OPERATION, B.ITEM_NAME FROM S_DOCK_TXN_LOG A RIGHT OUTER JOIN S_DOCK_TXN_LOG B ON B.PAR_TXN_ID = A.ROW_ID WHERE A.ROW_ID IS NULL
If you find a gap in transaction ID numbers, then use the Txnskip utility.
An orphan record does not necessarily cause a gap in transaction ID numbers. For situations where you find a gap, you can use the Txnskip utility instead of the Endtxnutl utility. For more information, see Using the Txnskip Utility to Examine Skipped Transactions.
