Troubleshooting a Transaction Merger Problem
This topic describes how to use a temporary solution to restart Transaction Merger until you can determine the root cause of the problem.
To troubleshoot a Transaction Merger problem
To identify the remote client and the DX file that is involved with this problem, examine the log file of the Transaction Merger.
For more information, see Example Log File for Transaction Merger and Naming Conventions for Log Files.
If the error is specific to one remote client, then you can rename the
INBOXfolder for this remote client.For example, rename the
C:\siebel\ses\siebsrvr\docking\sadmin\inboxfolder toC:\siebel\ses\siebsrvr\docking\sadmin\inbox_old.This is a temporary solution because the remote client cannot synchronize.
Restart the Transaction Merger server component.
If Transaction Merger runs, then this problem only affects one remote client. If Transaction Merger fails again, then the failure applies to multiple remote clients.
Get help.
For help with a Transaction Merger problem, see Getting Help from Oracle. Be prepared to send the related DX file and the trace file.
