Enabling Cookies for Siebel Business Applications
This topic describes how to enable the Microsoft Internet Explorer Web browser to handle cookies used by Siebel CRM. These instructions can vary depending on your supported browser version.
Note: If you are using a browser other than Internet Explorer to run Siebel CRM, see your browser documentation for information on enabling cookies.
To enable cookies using Internet Explorer
  1. Choose Tools, and then Internet Options.
  2. Click the Privacy tab.
  3. In Privacy settings, click Advanced.
  4. Verify that Override automatic cookie handling is checked. Also consider:
    • If First-party Cookies is set to Accept, then all Siebel cookies are enabled.
    • If First-party Cookies are blocked, then you can still enable the session cookie by checking Always allow session cookies.
  5. Click OK, then click OK again.
