Unsupported Keywords for Siebel Open UI Keyword Automation
The following keywords are not supported for Siebel Open UI keyword automation testing.
Calendar(Change slot of Call/Activity)
Dispatch Board
Intelligent Advisor
Find Result Pane
Search Result Pane
Charts
Promotion Designer
Gantt (Diary)
Task Pane items
Gantt Chart - Promotion List
A script recorded in any language (for example, DEU) can be played back in the same language (DEU in this case).
A script recorded in ENU cannot be played back in any other NON ENU language (like DEU, JPN, and so on).
You can make a note of the different scenarios and the corresponding values to be entered in the resource.xml file. The different scenarios and values listed in the following table are applicable only for NON ENU languages.
| S.No. | Scenario where Resource file needs to be updated | Value needs to be updated in Resource File |
1 |
Column Display (Hide, Show, MovingUP, MovingDown |
Selected Field Value should be entered Resource File |
2 |
Verify the Error/Warning message |
Error/Warning message in NONENU Language |
3 |
Toggle Value |
Selected Togglevalues should be entered in NONENU languages |
4 |
Verify Short Date |
Short Date in correspending NONENU language format |
5 |
Verify Long Date |
Long Date in correspending NONENU language format |
6 |
Verify Date Time |
Date Time in correspending NONENU language format |
7 |
Verify Value - Numeric |
Numeric value should be entered in correspending NONENU language format |
8 |
Verify Value - String |
Translated string value |
9 |
Verify Value - DateTime/Date |
Date Time in corresponding NONENU language format should be entered |
10 |
Any string value present in Combo box |
Data LIC value should be entered |
11 |
Visibility DropDown value |
Translated value of visibilty drop-down should be entered |
12 |
Verifies Button Existence/Absence |
Translated name of the button should be entered |
13 |
Verifies Column name Existence/Absence |
Translated name of the column should be entered |
14 |
Verifies Menu Item Existence/Absence |
Translated name of the MenuItem should be entered |
15 |
Verifies Existence/Absence of Label of any field |
Translated name of the Label should be entered |
16 |
Verifies the Presence/Absence of RadioButton on the Popup |
Translated value of radio button label should be entered |
17 |
Compare strings values |
Translated string value should be entered |
18 |
Compare numeric values |
19 |
Compare date/DateTime values |
Date/DateTime value should be entered in correspending NONENU language format |
20 |
Picklist applet -if any combo box value need to be selected |
21 |
MVG applet -if any combo box value need to be selected |
22 |
Application level Menu Item verification |
23 |
Selection of Radio button in export and import |
Labels translated value should be entered |
24 |
Selection of Radio button in Advance Sort |
LIC values of drop-down should be entered |
25 |
In simple query - query with any combo box value |
Data LIC value should be entered for query combo box |
26 |
Verify the Application level Menu Enable/Disable |
Translated value of Application level menu should be entered |
27 |
Verify the Applet level Menu Enable/Disable |
Translated value of Applet level menu should be entered |
28 |
Verify Label in any form applet |
Translated value of Label should be entered in File |
29 |
Verify applet level record count (1 - 30 of 30+) |
Translated Record count value should entered in file |
30 |
Applet level search option |
Data LIC value for combo box value should be entered |
