Configuring Oracle FLEXCUBE Universal Banking Integration Components
This topic provides a high-level overview of the tasks you must perform to install and configure Oracle FLEXCUBE Universal Banking components for the Integration. Detailed information on each of these tasks is available in the Oracle FLEXCUBE Universal Banking documentation provided with your application.
This task is a step in Roadmap for Installing and Configuring the Integration.
To install and configure Oracle FLEXCUBE Universal Banking integration components
  1. Copy the contents of the installation files for Oracle FLEXCUBE Universal Banking from the CD provided by the Oracle FLEXCUBE Universal Banking product distribution group.
  2. Consolidate the sources from the following releases in the order shown:
    1. FC_UBS_V.UM_11.0.0.0
    2. FCUBS_11.0.6 with patch P01
  3. Install the Oracle FLEXCUBE Universal Banking application.
    For information on this task, see the Oracle FLEXCUBE Universal Banking documentation that is provided with the product software.
  4. Install and configure the Oracle FLEXCUBE Universal Banking integration components (the EBO Direct Build utility) that allow the Oracle FLEXCUBE Universal Banking and Siebel CRM applications to be integrated.
    For detailed information on these tasks, see FCUBS EBO Direct Build Utility User Guide.
After configuring the Oracle FLEXCUBE Universal Banking integration components, you must perform several other tasks before the Oracle Data Integrator batch data processes can run. For information on these tasks, see Performing Batch Data Loading.
