Building JCL Templates for the Target Database
Perform the following procedure to build the JCL templates for the target database.
To build JCL templates for the target database
- On the Staging Database File Generation Menu, select option 7: Build Target Database JCL Templates, and press Enter. - This option applies target database LPAR, Tableowner and STORGROUP values to the JCL templates that were created to run the preupgrade and upgrade (in-place) processes for the staging database so they are appropriate for the target database upgrade.
- Submit the JCL in one of the following data sets: - For Siebel Industry Application (SIA) upgrades, use - DSNHLQ.SIEBEL.INSTALL.JCL(ALLSIAS.
- For Siebel Business Applications upgrades, use - DSNHLQ.SIEBEL.INSTALL.JCL(ALLHORS).
- Verify that the job ran successfully with a return code of 0 or 4. For information, see Verifying JCL Upgrade Jobs.
- After submitting the job, enter cancel on the command line or press PF3 to save changes.
- Press PF3 twice to return to the Staging Database File Generation Menu. - When you successfully complete the target database file generation process, the File Generation option (1) on the Siebel In-Place Upgrade Main Menu is no longer available. You are now ready to start the target database pre-upgrade and upgrade processes.
