Customizing the JCL UNIT Parameter Value
If appropriate for your environment, you can amend
the UNIT=SYSDA parameter setting for all of the JCL
generated for the Siebel upgrade before you run any jobs on the mainframe.
The UNIT=SYSDA parameter can be amended in the following
data sets:
- JOB0
- Any of the VSTG000n or VSTG00nn data sets
To amend the UNIT parameter setting
- Navigate to the data set you want to amend. Make a backup copy of the data set.
- Go to Edit mode on the data set.
- To change the UNIT=SYSDA parameter, enter the following command on the command line: - c sysda sgunit all- where sgunit is the unit name you want to specify.
- Press PF3 to save your changes. - All the JCL generated by the data set will use the new value you specified.
If you want to revert to the default UNIT parameter settings, either restore the backup copy of the data set
you made in step 1 or transfer the staging data sets from the midtier
again.
