Process of Preparing the Storage Layout of the Schema
Upgrades: All upgrades.
Environments: All environments
Before starting the upgrade, you have to prepare the storage control file you will use during the upgrade.
The storage control file contains information about physical schema attributes, including bufferpools, table space name and database name, that is used as the basis for the storage layout of your new 8.x Siebel database. Even if you are using a preconfigured storage layout, you must make sure that the layout is valid for your schema.
To preparing the storage control file, perform the following tasks:
Review the following:
There are different starting points from which you can customize your storage layout:
Scenario 1. Begin with a Siebel-provided storage layout template, import the template into the Siebel Database Storage Configurator (dbconf.xls), customize it, then export it as your customized layout.
Scenario 2. Use your current configuration from an existing database layout and merge it with one of the Siebel-provided templates. This can then be imported to the Siebel Database Storage Configurator for further manipulation. For more information on the Siebel Database Storage Configurator, see Implementing Siebel Business Applications on DB2 for z/OS.
To prepare the storage control file, use the Database Configuration Wizard to extract the storage layout of your database from the DB2 catalog. As part of the extraction process, you can merge the storage layout information from your existing database with information you already input into a storage template file or information in a template provided with Siebel Business Applications.
As an alternative, instead of extracting the storage layout of your existing database, you can use a template provided with Siebel Business Applications as the storage control file. For more information about templates for the storage control file, see Implementing Siebel Business Applications on DB2 for z/OS. Siebel Business Applications provide the templates listed in the following table for the storage control file.
| Template | Description |
storage_np.ctl  |
Database storage layout for a nonUnicode Siebel schema with no partitioning scheme  |
storage_np_u.ctl  |
Database storage layout for a Unicode Siebel schema with no partitioning scheme  |
storage_p.ctl  |
Database storage layout for the Siebel schema with partitioning for a set of tables on an ASCII database  |
storage_p_e.ctl  |
Database storage layout for the Siebel schema with partitioning for a set of tables on an EBCDIC database  |
storage_p_u.ctl  |
Database storage layout for the Siebel schema with partitioning for a set of tables on a Unicode database  |
