Post Installation Database Update Report
A report called PostInstallDBSetup_<Timestamp>.html is
                  automatically generated after you run the PostInstallDBSetup utility. This report
                  is in HTML format, is located in
                        siebsrvr\log\PostInstallDBSetup_<Timestamp>.html, and
                  provides information about the update including the following:
The objects that are delivered out-of-the-box.
The seed, schema, and manifest data that was imported as part of the database update process for a monthly update.
Any area or step where the PostInstallDBSetup utility fails.
To review the Post Installation Database Update Report
Go to the following location on your local drive:
siebsrvr\log\PostInstallDBSetup_xxxxxxxxxDouble click
PostInstallDBSetup_<Timestamp>.htmlto open the report you want to view, where<Timestamp>represents the date and time that the report was generated and is in the following format: YYYY-MM-DD_HR-MIN-SEC.In the Report console that opens:
Click Upgrade Summary to review summary information about all the steps that were run as part of the Post Installation Database Update process. Summary information is available for the following: Parameters, Initialization, WSRanking, SeedSchemaManifest Upgrade, and WorkflowUpgrade. Subcategories that appear under SeedSchemaManifest Upgrade include the following:
Initialization. Shows summary information related to initialization tasks and the status of each step (Completed/Failed/Error) in the process. Initialization tasks include validation of parameters, customer's database version, and database connectivity.
Schema. Shows summary information related to schema import and the status of each step (Completed/Failed/Error) in the process.
Manifest. Shows summary information related to schema and data import and the status of each step (Completed/Failed/Error) in the process.
 Seed. Shows summary information related to data import and the status of each step (Completed/Failed/Error) in the process.
Click Schema to review the names of the tables and columns that were updated out-of-the-box.
Click Manifest to review the basic user key information for all
S_UI*tables. Click Seed to review all the tables (and user key information) for which seed data was released.
Click Troubleshoot to review and troubleshoot errors that occur during Post Installation Database Update.
