Using REST API with the Migration Schema Service
The Migration Schema Service migrates the physical Siebel schema from the source environment to the target environment. The following table includes the methods supported for the Migration Schema Service.
| Method | Definition |
Export  |
Method used to export a schema for a migration. For more information, see Exporting with the Migration Schema Service.  |
Import  |
Method used to import a schema for a migration. For more information, see Importing with the Migration Schema Service.  |
GetWatermark  |
Method used to get a watermark for a migration. For more information, see Getting a Watermark with the Migration Schema Service.  |
IsSchemaChanged  |
Method used to check if a schema has changed for a migration. For more information, see Verifying If a Schema Changed with the Migration Schema Service.  |
GetStatus  |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Schema Service.  |
