Arguments for the Add To Cart Method
The arguments for the AddToCart method are shown in the following table.
| Name | Type | Data Type | Optional | Comments |
Action |
Input |
String |
Y |
Specifies the action to take. Action can take the following values:
AddToCart Quote Fields |
Input |
String |
Y |
This argument is used to pass the field values set in the Quote business component. It is a concatenated string of Quote business component field name/value pairs. The input value is in the following format: For example, if you set the Description and Discount Reason fields, then the input user property value is as follows: Note: This only impacts new quotes, and not existing quotes. AddToCart deconstructs this string and sets the corresponding fields in the Quote business component. |
AddToCart Quote Item Fields |
Inputs |
String |
Y |
This argument is used to pass the field values set in the Quote Item business component. The input value is in the following format: For example, if you want to set the Adjust List Price, Base Price, and Quantity Requested fields, then the input user property value is as follows: Note: If you set a field that triggers a reprice,
such as Quantity Requested, then that field must be set at the end
of the string. |
AddToCart AutoQuote |
Input |
String |
Y |
Used to decide whether to create a new quote automatically if there is no current quote. If empty, AddToCart looks for the server component parameter with the same name. |
AddToCart GotoView |
Input |
String |
Y |
Used to decide to which view to navigate after adding an item has been completed. If empty, AddToCart looks for the server component parameter with the same name. |
Source Currency Code |
Input |
String |
Y |
Specifies the currency code for the price. If not empty and not equal to the currency code in the quote, AddToCart does the currency conversion and sets the converted Price field in the quote item. |
Quote Id |
Output |
String |
Y |
Returns the quote ID for the current quote. |
Quote Item Id |
Output |
String |
Y |
Returns the quote item ID. |
ReturnVal |
Output |
String |
Y |
Returns Success or Fail. Not used. |
