Arguments for the DiscardCart Method
The arguments for the DiscardCart method are shown in the following table.
| Name | Type | Data Type | Optional | Comments |
Return Error Code |
Input |
String |
Y |
If equal to N, the method will not return errors. When a method returns an error, the workflow stops. To avoid stopping the workflow, you can set this input to N. This way the Shopping Service will not return an error, but instead save the error message in the output argument Error Message. You can then handle the error message as you want. |
Error Message |
Output |
String |
Y |
Stores error messages. |
ReturnVal |
Output |
String |
Y |
Returns Success or Fail. Not used. |
