Arguments for the SaveCartAsTemplate Method
The arguments for the SaveCartAsTemplate method are shown in the following table.
| Name | Type | Data Type | Optional | Comments |
Quote Name |
Input |
String |
Y |
Saves the Shopping Cart as a template with this name. |
Quote Name Field |
Input |
String |
Y |
Tells the Shopping Service which field is the quote name. By default, it is Name if this input argument is not used. |
Return Error Code |
Input |
String |
Y |
If equal to N, the method will not return errors. When a method returns an error, the workflow stops. To avoid stopping the workflow, you can set this input to N. This way, the Shopping Service will not return an error but instead save the error message in the output argument Error Message. You can then handle the error message as you want. |
Error Message |
Output |
String |
Y |
Stores error messages. |
ReturnVal |
Output |
String |
Y |
Returns Success or Fail. Not used. |
