Configuring Required Values
The following table describes the values you must provide if you configure a Workflow Policy program that inserts a new record. For more information, see Siebel Data Model Reference on My Oracle Support.
Required Values | Values Not Required |
If you configure a Workflow Policy program that inserts a new record, then you must provide a value for each field that Siebel CRM requires to add this record. If you configure a default value for a column, and if the Workflow Policy program does not specify a value, then Siebel CRM uses that default value on the insert. For example, the S_EVT_ACT table includes the following required columns:
Siebel CRM sets ROW_STATUS to Y by default. |
Siebel CRM does not require a value for a system column. For example, the following columns are system columns:
