Guidelines for Using an SQL Statement with a Workflow Policy Program Argument
If you use an SQL statement with a Workflow Policy program argument, then it is recommended that you adhere the following guidelines:
Make sure the table name and column name are in upper case.
You must prefix the case-sensitive table name with the following value:
&Table_OwnerMake sure the RDBMS you use supports the SQL statement.
It is recommended that the SQL statement return only one record.
Siebel CRM can use only one Workflow Policy program argument that uses an SQL statement for a Workflow Policy program. Do not use two or more Workflow Policy program arguments that use SQL statements for a given Workflow Policy program.
Use an SQL tool that is external to Siebel CRM to test your statement.
Caution: It is recommended that you thoroughly test your SQL statement in the context of
the Workflow Policy program before you implement it in a production environment.
