Input Argument Fields
The following table describes fields that you can define on an input argument for the business service step, sub process step, and wait step.
| Field | Description |
Business Component Field |
Specifies the name of a business component field. For Business Component Field input arguments. |
Business Component Name |
Specifies the name of a business component that the business object references. For Business Component input arguments. |
Changed |
N/A |
Input Argument |
(Required) Specifies the name of the input argument. For the business service step only. The drop-down list displays input arguments that exist for the business service method that you choose. If you define a method argument as a business service method argument, and if the Hidden field is set to FALSE, and if the type is Input or Input/Output, then the method argument displays in this drop-down list. |
Preferred Sequence |
For the business service step only. |
Property Name |
Specifies the name of the process property. For the Process Property input argument. |
Subprocess Input |
Specifies the name of the input argument. For the sub process step only. |
Type |
(Required) Specifies the type of argument. You can choose one of the following values:
Value |
Specifies a string value. For Literal or Expression input arguments. This value can be in a drop-down list, depending on the argument that you choose. A string value can contain a maximum of 32,767 characters. |
