Starting a Workflow Process from a Custom Toolbar
The following procedure guides you through one example of starting a Workflow Process from a custom toolbar. In this example, a new button is added to the Toolbar and the Workflow Process starts when the button is clicked.
To start a Workflow Process from a custom toolbar
(Optional) Display the Command object type and the Toolbars object type in the Object Explorer.
Navigate to the Business Services list and create a new business service with the values shown in the following table.
Property
Value
Name
TestTBItem
Server Enabled
TRUE
Navigate to the Commands list and create a new command with the values shown in the following table.
Property
Value
Name
TestTBItem
Business Service
TestTBItem
Method
TestTBItem
Target
Server
In the Object Explorer, click Toolbar, and then query the Name property in the Toolbars list for the following value:
HIMainIn the Object Explorer, expand the Toolbar object and click Toolbar Item.
In the Toolbar Items list, create a new record with the values shown in the following table.
Property Value Name
TestTBItem
Command
TestTBItem
DisplayName
TestTB Item
Type
Button
HTML Type
Button
Position
20
In the Siebel client, define a Workflow Process and make sure it can run successfully from the Process Simulator.
For more information, see Process of Testing a Workflow Process.
Add the following server script to the business service that you defined in step 2 (TestTBItem). You must use the name of the Workflow Process that you specified in step 7:
function Service_PreCanInvokeMethod (MethodName, &CanInvoke) { var returnValue = ContinueOperation; if (MethodName == "TestTBItem") { CanInvoke = "TRUE"; returnValue = CancelOperation; } return (returnValue); } function Service_PreInvokeMethod (MethodName, Inputs, Outputs) { var returnValue = ContinueOperation; if (MethodName == "TestTBIItem") { try { var psInput = TheApplication().NewPropertySet(); var psOutput = TheApplication().NewPropertySet(); var svc = TheApplication().GetService("Workflow Process Manager"); psInput.SetProperty("ProcessName", "<WF Process Name Created Above>"); svc.InvokeMethod("Run Process", psInput, psOutput); returnValue = CancelOperation; } // end try finally { svc = null; psOutput = null; psInput = null; } // end finally } // end if return(returnValue); }Test your changes using a Siebel Client Application Object Manager.
Make sure Siebel CRM displays the new button in the toolbar. Click it to make sure the correct Workflow Process starts.
