Starting a Workflow Process from a Script That Sends Field Values to Process Properties
The example in the following script starts a Workflow Process named My Opportunity Process that starts in the Object Manager. Siebel CRM passes field values to the process properties that are defined in the Workflow Process:
//Example: Passing Field Values to Process Properties
function Invoke_Process()
var svc = TheApplication().GetService("Workflow Process Manager");
var Input = TheApplication().NewPropertySet();
var Output = TheApplication().NewPropertySet();
var bo = TheApplication().ActiveBusObject();
var bc = bo.GetBusComp("Opportunity");
var rowId = bc.GetFieldValue("Id");
var accountId = bc.GetFieldValue("Account Id");
Input.SetProperty("ProcessName", "My Opportunity Process");
Input.SetProperty("Object Id", rowId);
// Pass the value of the Account Id field to the Account Id process property
Input.SetProperty("Account Id", accountId);
svc.InvokeMethod("RunProcess", Input, Output);
