Using Compare To Options
The following table describes Compare To options and their required and optional values.
| Compare To | Operation | Object | Field | Value |
Applet. Compare the runtime value of an applet control or list column to a literal. |
Comparison operation. All operations are allowed. |
The name of the applet. |
The column in the applet. |
One or more literals for comparison. |
Business Component. Compare the runtime value of a business component field to a literal. |
The name of the business component. |
The field in the business component. |
Expression. Evaluate expressions and determine if they return true. |
Specifies how to evaluate multiple expressions. Only applicable if the Values property includes multiple expressions. The following choices are available:
For more information, see Using Simple Comparison Operations and Using Substitution Variables in an Expression. |
Optional. If the expression references a business component field, then the object is a business component name. You can reference the fields of only one business component in the expression. |
N/A |
One or more expressions. |
Process Property. Compare the runtime value of a process property to a literal. |
The name of the process property. |
N/A |
