Using Decision Conditions with a Decision Step
You can use a decision condition to determine the flow that Siebel CRM must take on a branch in a Workflow Process. A decision step can exist with multiple connectors where each connector represents a logical branch. Siebel CRM can evaluate a decision condition for each connector that provides branching. A decision condition can make a comparison between two of the following items:
Process properties
Business component fields
Literal values
A comparison can include the following terms:
Two values that are equivalent.
One value exists among a series of other values. For example, child record values, One Must Match, or All Must Match.
Greater than (
) or less than (<
).Between or Not Between.
Null or Not Null.
For an example that uses the Compose Condition Criteria dialog box, see Defining a Decision Condition for a Decision Step. For a description of properties that the Compose Condition Criteria dialog box displays, see Creating a Decision Condition on a Branch Connector.
