Using the Process Simulator to Start a Workflow Process
You can use the Process Simulator to start a Workflow Process, and then immediately test and debug it. You can debug Workflow Process steps while you define them in the Repository.
When you use the Process Simulator to start a Workflow Process, it is run in the context of an Application Object Manager (AOM) such as Siebel Call Center.
For more information, see Starting a Workflow Process.
