Setting the System Preferences for Integration
Administrators must set system preference values. The system preferences listed in this topic control aspects of Oracle Application Integration Architecture integration functionality.
To set the system preferences for integration
Navigate to the Administration - Application screen, then the System Preferences view.
Query for the Oracle Application Integration Architecture integration system preferences, and set the appropriate value for each.
Oracle Application Integration Architecture integration system preferences are described in the follow table.
System Preference Comments Cancel Error Mode
Controls the behavior when an order that has future-dated line items is cancelled. Those future-dated line items are affected by the cancellation of this order. Values are as follows:
1 Do not display warning messages.
2 Display warning messages.
3 (Default) Display warning and error messages, and stop processing.
Validate Due Date
Controls the behavior of the pop-up applet that prompts for the Due Date for change orders such as Modify, Disconnect, Suspend, and Resume. Values are as follows:
1 No warning messages appear. Modify, Suspend, Resume, and Disconnect (MACD) operations are continued for assets and orders.
2 (Default) Display warning messages. Enable the Continue button on the Due Date window.
3 Display warning messages. Disable the Continue button on the Due Date window.
Enable AIA Comms
Controls whether to enable the Oracle Application Integration Architecture Communications integration features. Values are as follows:
TRUE Enable Oracle Application Integration Architecture Communications integration features.
FALSE Disable Oracle Application Integration Architecture Communications integration features.
Enable AIA Testing
Controls whether to enable the Oracle Application Integration Architecture Communications integration testing features. Values are as follows:
TRUE Enable Oracle Application Integration Architecture Communications integration testing.
FALSE Disable Oracle Application Integration Architecture Communications integration testing.
AIA Order Backup Path
XML files are available on the specified path, with file names in the form OrderNumber_RevisionNumber.xml. The files can be sorted by Date Modified. Enabled only if the Enable AIA Testing system preference is set to TRUE. Value is as follows:
/export/home/qa1/orderbackup/Workspace Release Flag
A product that is synchronized from Oracle Product Information Management Data Hub is a workspace version, that is, a test version, in Siebel CRM. This system preference holds or releases all the products associated with a workspace. This system preference appears in the SWIProductImportIO, SWIAttributeImportIO, and SWIProductClassImport Web services.
Additionally, a Product Release Flag in each product definition can be used to release the individual product.
The Workspace Release Flag system preference has the following values:
N. Default value. Siebel CRM does not automatically release the products.
In this case, a user can set the Product Release Flag of an individual product to Y to release that specific product, and all the other products in the same payload are not released.
Y. Siebel CRM automatically releases the products.
In this case, all the products belonging to the Workspace are automatically released. This setting overrides the Product Release Flag settings of the individual products in the Workspace.
D. Signifies a default or empty value.
In this case, the default value of this system preference, which is N, determines whether to automatically release the product.
Enable AIA MDM
Enables or disables the MDM (Master Data Management) PIP. Default value is set to FALSE. To enable the MDM PIP, you must change this system preference value to TRUE and restart the Siebel Server.
Enable AIA OrderToCash
Enables or disables the Order-to-Cash PIP. Default value is set to FALSE. To enable the Order-to-Cash PIP, you must change this system preference value to TRUE and restart the Siebel Server.
Caution: It is recommended that you not set the Enable AIA Comms and Enable AIA OrderToCash system preferences to TRUE in the same Siebel CRM instance. Interoperability of Siebel Communications PIPs (Order-to-Bill and Agent Assisted Billing Care) with the Order-to-Cash PIP is not tested or supported by Oracle.AIA Version
Specifies the version of Oracle Application Integration Architecture with which to integrate your Siebel application. The default and supported value is 2.5.1 (for Oracle Application Integration Architecture Version 2.5.1).
Caution: If you select any other value (not specified in AIA Version), then the application might not function as expected.Set other system preferences, if necessary.
For more information about system preferences, see Siebel Applications Administration Guide.
