Limiting and Sorting Axis Points
You can limit the number of X-axis or Z-axis labels to a predefined number. The X-axis defines the category and the Z-axis defines the series. You can use this feature to display only the N highest or N lowest values for a field or calculated Y value. For example, to display the 10 highest revenue accounts, you can chart the Revenue field in descending order and limit the X-axis to 10 data points.
To limit and sort axis points
Complete Step 1 through Step 5 in procedure Configuring the Show List of a Chart Applet.
In the Object Explorer, expand the Chart tree, and then click Chart Element.
In the Chart Elements list, define properties of the axis label chart element, using values from the following table.
| Property | Description |
Divisions |
Defines the X-axis or the Z-axis. Enter an integer to limit the number of X-axis or Z-axis labels. Siebel CRM limits the number of labels it displays to the number you enter. Note the following:
Sort Specification |
Defines the Y-axis. Enter
