Using the Track Calendar
Using the Track Calendar, you can view the scheduled sessions for several tracks side by side in a day-planner format.
The following procedure describes how to use the Track Calendar.
To use the Track Calendar
  1. Navigate to the Site Map > Events > Event Plans view.
  2. From the visibility filter, select All Events.
  3. In the All Events list, select and drill down on the Event Plan Name.
  4. Click the Schedule view tab and then click Events.
  5. In the Events list, drill down on the Event Name.
  6. Click the Schedule view tab, and then click Track Calendar.
Alternatively, you can view track-related events, sessions, and members in the standard list and form views by choosing the corresponding view tabs on the Tracks screen.
