TNT SHM Calc Revenue For Which Field
Use this user property to indicate which amount taxes and service charges must be calculated for.
| TNT SHM Calc Revenue For Which Field | Description |
Value |
ForAdjusted |
Parent Object Type |
TNT SHM Room block Rates, TNT SHM Room block Rates Pending business components |
Usage |
This user property is used to indicate which amount taxes and service charges must be calculated for. The default ForAdjusted value calculates the sum of taxes and service charges for the guest invoice. The ForOriginal value calculates the sum of taxes and service charges for the accounting invoice. |
