Creating the JVM Subsystem for Safety System Integration
This task describes how to create the JVM subsystem required for safety system integration.
This task is a step in Process of Setting Up Safety System Integration for Siebel Medical.
To create the JVM Subsystem for safety system integration
In the Siebel application, navigate to the Administration - Server Configuration screen, then the Enterprises view.
Select the Enterprise Server that you want to configure, and then click the Profile Configuration tab.
Create a new enterprise profile record and complete the necessary fields.
Set the following parameters on the form that appears:
Name Value Profile
JAVA
Alias
JAVA
Subsystem Type
JVMSubsys
Set the following parameters in the Profile Parameters list applet.
Name Alias Data Type Value JVM Classpath
CLASSPATH
String
Set the classpath value as follows:
Windows. The files in the classpath must be separated by semicolons (;) and end with a semicolon and period (;.), for example:
D:\WLSJMS;D:\WLSJMS\Siebel.jar;D:\ WLSJMS\SiebelJI_enu.jar;D:\WLSJMS\ wlfullclient.jar;.-
UNIX. The files in the classpath must be separated by colons (:) and end with a colon and period (:.), for example:
/usr/wlsjms:/usr/wlsjms/ Siebel.jar:/usr/wlsjms/ SiebelJI_enu.jar:/usr/wlsjms:.
JVM DLL Name
DLL
String
Set the path to the JVM library file, for example:
Windows:
<JAVA_HOME>/jdk/jre/bin/server/ jvm.dll-
UNIX:
<JAVA_HOME>/jre/lib/sparc/client/ libjvm.so
JVM Options
VMOPTIONS
String
Set the JVM-specific options for the log file, for example:
Windows:
-Djms.log=D:\WLSJMS\log\jms.log-
UNIX:
-Xusealtsigs -Xrs -Djms.log=/usr/ wlsjms/log/jms.log
