Creating the Oracle WebLogic Full Client JAR for Safety System Integration
This task describes how to create the Oracle WebLogic full client JAR required for safety system integration. You use the Oracle WebLogic JarBuilder tool to generate the full client JAR. The JAR file is then added to the classpath.
This task is a step in Process of Setting Up Safety System Integration for Siebel Medical.
To create the Oracle WebLogic full client JAR for safety system integration
Log on to the Oracle WebLogic server.
Change the directory to the
server/libdirectory, using the following command:cd WL_HOME/server/libCreate wlfullclient.jar in the
server/libdirectory, using one of the following commands.JDK Version Command Version 1.5
java -jar wljarbuilder.jar -profile wlfullclient5Version 1.6
java -jar wljarbuilder.jarTo add the Oracle WebLogic full client JAR to the classpath, copy it to the
D:\WLSJMSdirectory on the Siebel Server.
